Question [Kunena 1.5.3 - Community Builder 1.2.1] All links in Forums are dead
16 years 9 months ago - 16 years 9 months ago #22483 by myle
I upgraded to the latest version of Kunena in order to have native support for Joomla 1.5.12. The problem is that even though the post are not lost (I did a recount of statistics), all the links in the forums (i.e Latest posts, Categories etc) are dead.
I followed the procedure as it is described here:
www.kunena.com/forum/138-support/19950-c...it=10&start=20#21107
After several repetitions with errors (missing parts), I think have completed it.
My errors were:
I unistalled previous version (1.2) of community builder and forgot to unistall some modules of it, so I had different versions. Fixed now.
I have installed several times the latest version of kunena hoping in a miracle. Does this mess with something?
Note: I had no problem in another almost identical forum where I upgraded having disabled community builder integration just before.
Last edit: 16 years 9 months ago by myle.
16 years 9 months ago #22517 by @quila
Hi myle,
can you provide a link to your site?
If you use a SEF components try to disable and see if change something.
Regards
16 years 9 months ago - 16 years 9 months ago #22522 by myle
Thanks for replying!
I don't know what SEF stands for.
The link you asked for is taspython.co.cc/forum.html .
Note: The site is in Greek.
UPDATE: With the @quila's help, the problem solved. Now the Kunena work well after having disabled SEO in Joomla configuration.
16 years 9 months ago - 16 years 9 months ago #22549 by sozzled
Congratulations on "solving" your problem. I am most surprised that you needed to disable the standard Joomla SEO functions! I'm not surprised that your K 1.5.3 forum now reverts to the old search engine "unfriendly" URLs. I think what quila was suggesting was to disable any third-party SEF products, such as sh404SEF (if you use such things).
I had a look at your problem a few hours ago and I was going to make a couple of suggestions. Before the moderators lock this topic as "solved" - I don't think this problem is solved - I suggest you read the article I wrote for the Wiki: Search engine optimization (SEO) .
The following image summarises the SEO settings that I would recommend you try:
Last edit: 16 years 9 months ago by sozzled.
16 years 9 months ago #22586 by myle
Interesting article.
If either of the suggested option are set, then I get an error which is effectively the same (links are dead). I tried it with both having a .htaccess file and not.
I can't find any third-party SEF product nor I can recall a deviation as described.
16 years 9 months ago #22600 by chema
Sorry for my bad english!!
On my site works fine with joomsef hacking this code in class.kunena.php:
// PROFILE LINK if ($fbConfig->fb_profile == "jomsocial") { $profilelink = 'index.php?option=com_community&view=profile&userid='; define("KUNENA_PROFILE_LINK_SUFFIX", "index.php?option=com_community&view=profile&Itemid=" . KUNENA_JOMSOCIAL_ITEMID . "&userid="); } else if ($fbConfig->fb_profile == "cb") { $profilelink = 'index.php?option=com_comprofiler&task=userProfile&user='; define("KUNENA_PROFILE_LINK_SUFFIX", "index.php?option=com_comprofiler&task=userProfile" . KUNENA_CB_ITEMID_SUFFIX . "&user="); } else if ($fbConfig->fb_profile == "clexuspm") { $profilelink = 'index.php?option=com_mypms&task=showprofile&user='; define("KUNENA_PROFILE_LINK_SUFFIX", "index.php?option=com_mypms&task=showprofile&Itemid=" . KUNENA_CPM_ITEMID . "&user="); } else { $profilelink = 'index.php?option=com_kunena&func=fbprofile&task=showprf&userid='; define("KUNENA_PROFILE_LINK_SUFFIX", "index.php?option=com_comprofiler&task=userProfile" . "&user="); } }
The hack is in the last define.
My site is in spanish --> www.descargasjoomla.com/foros
Regards!!
DJ!! and KS!! Team
Time to create page: 0.244 seconds
