Question Installation of Kunena 1.5.3 on Joomla 1.5.11 by STRATO-Webhoster
As i can see, Kunena is beginning to install and the the installation is hanging and an Server 500 Error from the web-hoster is coming. Maybe that's a timeout-problem (30 second problem)
In the database no tables from kunena are created but in the Joomla-Frontend the "Kunena-Component"-Icon is visible, but it's not working
Error-Messages:
- Your Kunena installation is incomplete!
-Because of the above errors your Forum is now Offline and Forum Administration has been disabled.
- * Possible reasons for this error:
* 1) Kunena installation process has failed or timed out (try to install it again)
* 2) You have removed some of the Kunena tables from your database
* 3) Your database has been corrupted
* Our support forum can be found from: www.kunena.com
Did anybody had the same problems an could help me get this running? I think it's a timeout-problem with STRATO but maybe i can change the installation of kunena to get this fixed.
Greetings
Chris (getting mad with this!!) :woohoo:
did you try to install Kunena from directory? In this way you bypass the 30 second problem.
Regards
I had the same problem at the hoster domainfactory.de with the Installation of Kunena 1.5.3 b1688 - Error 500.
The installation about the directory ist not possible because he don't find a xml... But I think, that is not the problem - it seems not to be a timeaout.
Any other ideas?
My PHP-Version: 5.2.8
My Database Version: 5.0.51
I use sh404sef with .htaccess
Apart from that a clean installation of 1.5.11.
Regards
Peter
www.autofahrer-aktuell.de
- dayakcinta
Parse error: syntax error, unexpected $end in /home/xxxmyhost/public_html/administrator/components/com_kunena/toolbar.kunena.php on line 92
plese help me,
i installed kunena from the /tmp - folder, but that's not the problem, what i can see, is that all files of kunena are transferred to the right places (admin-Folder, components folder) but in the database no new tables are created.
Does anybody know how to debug the installer procedure of kunena?
My System-Info:
PHP erstellt für: SunOS localhost 5.10 Generic_125100-10 sun4v
Datenbankversion: 5.0.67-log
Datenbankzeichensatz: utf8_general_ci
PHP-Version: 5.2.9
Webserver: Apache/2.2.11 (Unix) mod_fastcgi/2.4.6
PHP-Anbindung zum Webserver: cgi
Joomla!-Version: Joomla! 1.5.11 Production/Stable [ Vea ] 03-June-2009 03:30 GMT
It's all a new clean installation of joomla in the german version, maybe that's the problem?
But error 500 seems to me not a speacial problem of language versions....
Chris :silly:
i found the mistake, it's due to corrupted Tables of the former Fireboard-Forum.
For the migration i used the "com_migrator" Joomla-component, but this seems to have problems with the "ä,ö,ü"-spellings, so some of the tables are not migrated in the right way.
So i changed this manually with a text editor and create/import the corrupt tables with the phpmyadmin.
The corrupted tables are easy to find, u only had to copy the jos_fb_xxx tables under a different name, everytime there's an error, the "error 500" is coming in phpmyadmin.
Afterwards i installed kunena without any errors. It's running very good, great forum.
:woohoo:
