Question The upgrade to 1.5.3 issue.
17 years 5 months ago - 17 years 5 months ago #20135 by tmaximus95
I had an older version of Kunena on my site. I saw the latest version and decided to upgrade it.
Once I upgraded, this is what I get:
Error
* Your Kunena installation is incomplete!
Notice
* Because of the above errors your Forum is now Offline and Forum Administration has been disabled.
Message
* Possible reasons for this error:
* 1) Kunena installation process has failed or timed out (try to install it again)
* 2) You have removed some of the Kunena tables from your database
* 3) Your database has been corrupted
* Our support forum can be found from: www.kunena.com
If there are tables missing or corrupted, can this be fixed? Also, all other parts of my site are working as usual, thank God.
Any help would be much appreciated.
tmax.
Last edit: 17 years 5 months ago by fxstein.
17 years 5 months ago #20138 by Lintzy
Did you do, what is written under Point 1 -> (try to install again)? Please delete the first kunena installation and try to install again with another archive format. If you uses .zip try with .rar.
Did you make a database backup, before installing Kunena, like it is recommend in every install instruction?
But don't panic, normally Kunena does never destroy database.
17 years 5 months ago #20145 by Matias
Kunena did nothing to the database tables. It just runs detection code to find all tables it uses and it looks like there were some tables missing in your previous installation.
Easiest way to get forum back to online is to install old version back to your site (it does not have that detection code). After that you should look at phpmyadmin (or similar tool) and list all the jos_fb_ tables you find in this thread.
I believe that you're missing jos_fb_version table?
17 years 5 months ago - 17 years 5 months ago #20154 by Lintzy
message content edited by fxstein
17 years 5 months ago - 17 years 5 months ago #20158 by fxstein
Error
Notice
Message
tmax.
Sorry about that.
Turns out the error message is a bit too harsh. We will need to rethink that.
Nothing has been corrputed, out of thousands of installs I have never seen a corrupted database. We appologize for the misleading error message.
What has most likely happened is that the install timed-out. Unfortunately a common Joomla 1.5 Installer issue. The Joomla installer can take a significant time to install a package and might hit the apache php timeout of 30 sec default.
The result is usually a blank white screen at the end of the install, rather than a success message.
In the past many user did not realize that a blank page was cause for alaram and would go on to use the forum component, even though installation did not finish.
We now detect these and give you this error in the backend.
The workaround is usually simple: Increase the php timeout to 300 sec on your server and re-install.
If that is not possible you can ftp the unzipped package into a seperate folder on your server and use the Joomla option to install from an existing directory.
That way you don't go through the slow Joomla installer and the sinatllation will finish quickly.
Again not reason to be alarmed. We appologize for the harsh error message.
Thx!
fxstein
PS: I have edited the thread topic to reflect that
17 years 5 months ago - 17 years 5 months ago #20164 by push_jwc
Replied by push_jwc on topic upgrade to 1.5.3
im getting this error message when i try to go to the kunena link i the administrator back end. when i click on components>> kunena form i get the following message:
Parse error: syntax error, unexpected $end in /home/pushjwc/public_html/beta/administrator/components/com_kunena/toolbar.kunena.php on line 92
Last edit: 17 years 5 months ago by push_jwc.
