Question 1.5.14 upgrade issue
15 years 9 months ago #83660 by kmilos
1.5.14 upgrade issue was created by kmilos
I have just tried upgrading to 1.5.14 from 1.5.13 (without uninstalling) and got an "XML error on 3:84", which is I presume because of the non-ASCII character in kunena.install.upgrade.xml
The result is "Upgrading Kunena to version 1.5.14 has failed!" at the top when I go to the component control panel, and "Installed version: Kunena 1.5.14 | 2010-11-04 | 1902 [ NOT UPGRADED ]..." at the bottom.
The following user(s) said Thank You: nguoiveday
15 years 9 months ago #83692 by testeuse
Replied by testeuse on topic Re: 1.5.14 upgrade issue
Hi, I have the exact same issue with kunena 1.5.14, i am trying to upgrade to 1.5.14 from 1.5.13 but it give me the same errors than Kmilos :
"XML error on 3:84" and "Installed version: Kunena 1.5.14 | 2010-11-04 | 1902 [ NOT UPGRADED ]..." at the bottom.
What can i do please? I can't use 1.6 because my editor is not showing in 1.6.
Please help !!
15 years 9 months ago #83701 by fxstein
Replied by fxstein on topic Re: 1.5.14 upgrade issue
What php version are you guys running on?
15 years 9 months ago #83704 by 810
Replied by 810 on topic Re: 1.5.14 upgrade issue
Hi, there seems to be a name conflict.
Try this:
manifest.xml line 5
<versionname>Comunità (Italian for: Community)</versionname>
change to:
<versionname>Comunita</versionname>
Regards 810
The following user(s) said Thank You: C.A.M
15 years 9 months ago #83715 by kmilos
Replied by kmilos on topic Re: 1.5.14 upgrade issue
@fxstein
PHP Built on: Linux xyz 2.6.32-22-server #36-Ubuntu SMP Thu Jun 3 20:38:33 UTC 2010 x86_64
Database Version: 5.0.51a-3ubuntu5.4
Database Collation: utf8_general_ci
PHP Version: 5.2.4-2ubuntu5.7
Web Server: Apache
Web Server to PHP interface: apache2handler
Joomla! Version: Joomla! 1.5.22 Stable [ senu takaa ama woi ] 04-November-2010 18:00 GMT
@810
Thanks, I figured already it's a name conflict. But then what? Try upgrade again? Uninstall/reinstall? Will it mess up my setup? I'd rather wait for an official and tested fix.
15 years 9 months ago #83716 by 810
hi, we have tested this. the fix will be in the next release. Its only a name error, so no setup setting/database settings will be lost.
1) Edit the manifest.xml in the package
2) Run update again, then the problem is gone.
