Question 1.5.14 upgrade issue
15 years 9 months ago - 15 years 9 months ago #83769 by Scottux
Replied by Scottux on topic Re: 1.5.14 upgrade issue
kmilos wrote: Thanks, I figured already it's a name conflict. But then what? Try upgrade again? Uninstall/reinstall? Will it mess up my setup? I'd rather wait for an official and tested fix.
Hello :)
Now, upgrading is OK for me with these modifications :
In file named manifest.xml :
Line 5, replace
<versionname>Comunità (Italian for: Community)</versionname>
with
<versionname>Comunita</versionname>
In file named kunena.install.upgrade.xml :
Line 3 and line 348, replace
"Comunitˆ (Italian for: Community)"
with
"Comunita"
Last edit: 15 years 9 months ago by Scottux.
The following user(s) said Thank You: kmilos, C.A.M, robytotem
15 years 9 months ago #83789 by kmilos
Replied by kmilos on topic Re: 1.5.14 upgrade issue
@Scottux, @810
Yep, editing only manifest.xml is not enough (at least not after the build is done.)
For a long term solution maybe adding
encoding="utf-8"
to the /trunk/1.5/administrator/components/com_kunena/install/kunena.install.upgrade.xml template would be best?
15 years 9 months ago #84294 by treehugger
Replied by treehugger on topic Re: 1.5.14 upgrade issue
This worked a treat - thank you.
The following user(s) said Thank You: nguoiveday
15 years 9 months ago #85058 by kmilos
Btw, this can also impact K1.6 and future K2.0 too, as reported:
joomlacode.org/gf/project/kunena/tracker...racker_item_id=24742
15 years 8 months ago #88803 by kmilos
Ping?
The missing encoding declaration impacts both K1.6 and K2.0 as well.
15 years 8 months ago #88830 by xillibit
Replied by xillibit on topic Re: 1.5.14 upgrade issue
kmilos wrote: @Scottux, @810
encoding="utf-8"
Yes, this a good solution
