Question installation problem with Kunena ... help me please !!
16 years 4 months ago #52266 by Robs
I try to install Kunena 1.5.12 on Joomla 1.5.18 and I have this error message:
componente Installa: DB function failed with error number 2006
MySQL server has gone away SQL=INSERT INTO jos_components VALUES( 0, 'Kunena Forum', 'option=com_kunena', 0, 0, 'option=com_kunena', 'Kunena Forum', 'com_kunena', 0, 'js/ThemeOffice/component.png', 0, '', 1 )
SQL =
Error Loading ModulesMySQL server has gone away SQL=SELECT id, title, module, position, content, showtitle, control, params FROM jos_modules AS m LEFT JOIN jos_modules_menu AS mm ON mm.moduleid = m.id WHERE m.published = 1 AND m.access <= 2 AND m.client_id = 1 ORDER BY position, ordering
I have installed MySQL 4.1.22 and phpMyAdmin 2.9.0
Can we help me please??
many thanks and best regards
R.
16 years 4 months ago #52269 by etusha
16 years 4 months ago #52271 by Robs
Ok, many thanks for the answer ..
I tryed with the MySQL updated version.
regards
Robs
16 years 4 months ago #52274 by Matias
"MySQL server has gone away"
Joomla does not detect MySQL timeouts, so it fails to connect back to database after copying the files. You need to increase MySQL connection timeout into 100-300 seconds depending on your environment.
