Question <strong> tags instead of bold tags in messages
14 years 11 months ago - 14 years 11 months ago #96729 by skybax
Hi my forum uses
<strong>text</strong>
for the Bold button and it doesn't work and i want to change that code in
<b>text</b>
can someone tell me how i can do that? Thanks
Last edit: 14 years 11 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes
14 years 11 months ago - 14 years 11 months ago #96736 by sozzled
This problem is caused by another plugin that you have installed. It is probably the RokCandy plugin from Rockettheme.
Please upgrade to K 1.6.4
14 years 11 months ago #96744 by skybax
i see.. bat still isn't there a way to modify the bold button function? because if i add it will work
14 years 11 months ago #96745 by sozzled
The <strong> tags are a plugin override from some other extension that you are using. If you search for <strong> on this forum you will see many examples of what causes it and what you should do about it.
14 years 11 months ago #96746 by skybax
thanks for the help
14 years 11 months ago #96748 by skybax
For future members how will have this problem simply disable System - RokCandy plugin and all will work.
Time to create page: 0.264 seconds
