Question Guests replies to topic do not display
sozzled wrote: What Kunena template are you using? Please see There is only one endorsed and supported Kunena template ... default_ex .
We are using the default template
sozzled wrote: Please do not use the default template. Please use the default_ex template. Thank you.
Sorry, by default, I meant the only option that was available with my distribution. That is the default_ex template.
We mainly use guests entries. No one signs in because it is a very small shop. I don't think the same problem occurs if you sign in.
I tried an experiment. Entered several replies and waited. They eventually showed up after several minutes. Then I tried the same experiment and cleared the page cache immediately. The replies showed up immediately. Any one have any insights on why this would happen and how to work around it????
Perhaps K 1.6 would be better for you? On the other hand, you could always change your browser settings so that it never uses caching.
sozzled wrote: You are now saying that guest replies to topics do appear but there's some time lag before that happens. I believe that you have identified the cause of the problem as a browser caching issue and, because of this,there will be a little delay in seeing and responding to guest questions. First time I've heard of this happening but, then again, we don't get many enquiries these days about K 1.5 issues.
thanks
