Question Missing "Edit" button for users
16 years 1 month ago - 16 years 1 month ago #65474 by ankoch
Help please. Kunena 1.5.12. Missing "Edit" button for users. That is, users can not edit your posts.
In the "configuration" of the forum - "custom" - "edit message" set - "yes".
How to solve the problem.
Thank you.
Last edit: 16 years 1 month ago by ankoch.
16 years 1 month ago #65515 by sozzled
What Kunena template are you using? When did this problem first start appearing? How long have you been using K 1.5.x? Is there some reason why you are not able to use K 1.6?
16 years 1 month ago #65530 by ankoch
Thanks for the reply. I use a template default_ex. "Edit" button is visible only to moderators and administrators, but not the author.
I use kunena 1.5.x about 1 month.
I do not use kunena 1.6 of the conflict mootools with other extensions.
16 years 1 month ago #65545 by ankoch
I solved the problem. The problem was actually in the template. The fact that I had changed the template and made a mistake. Now everything is OK. Thank you.
16 years 1 month ago #65633 by sozzled
Thanks for finishing your story. Please remember that, before you ask for support in these forums, make sure you can reproduce your problems using the standard, unmodified original Kunena product. As soon as you change the source code or the CSS - any of it - your version is no longer "standard" or "unmodified". If your version is not standard, or if you have modified it in some way, we might be able to help but there's a very good chance that we won't be able to help unless we know exactly all of the changes and modifications you have made.
The beauty of Kunena is that uses are able to change it any way they like. The problem is that users do change it. B)
The following user(s) said Thank You: ankoch
