Question BB coding
16 years 5 months ago #49121 by Jailescape
BB coding was created by Jailescape
Whenever I use the BB coding it always get's changed after posting. For example, if I were t use it would be changed to <strong> which doesn't work on my forums & makes <strong> show up in any posts with bold.
Is there anyway that I can fix this?
16 years 5 months ago - 16 years 5 months ago #49123 by Cerberus
Replied by Cerberus on topic Re:BB coding
can you provide me a login and th url of your site ( IN PM ) so i can see this for myself, as im certain i know the problem but want to make sure my answer fit exactly to your problem.
FYI: <strong> is not a BBCode tag its HTML and HTML will not work in kunena
Last edit: 16 years 5 months ago by Cerberus.
16 years 5 months ago #49130 by Jailescape
Replied by Jailescape on topic Re:BB coding
Like, if I use the BBcode as soon as it is posted it changes to <strong> and doesn't work.
16 years 5 months ago #49133 by Cerberus
BINGO!!!!
Took all of 3 seconds to find your issue, it is indeed a JS conflict caused by ROCKET THEMES, if you do a search of these forum you will find 100s of post regarding how bad they are and how many problem they cause and sadly there modules are worse for causing issue.
Some of the known culprits:
From Rocket Themes:
* RokBox
* RokCandy
* RokGZipper
From Others: ( so i dont sound like it only rocket themes that cause this )
* yvbbcode
* com_clickheat
* woopera plugin
16 years 5 months ago #49150 by Jailescape
OK. Well thank you :)
Seems like I fixed the problem by disabling those plugins lol
16 years 5 months ago #49153 by Cerberus
your very welcome :)
