Question UddeIM integration with Kunena question..
16 years 6 months ago #48608 by bigmike0601
Do I need to install the CB files for PM box to appear in Kunena profile field like this forum? I don't have CB, but will get it if I need these files for the integration to work properly.
Thanks,
Mike
16 years 6 months ago #48610 by xillibit
Here there aren't Uddeim or CB, to appear udeim links in your profile, you have just to install uddeim and enable integration in kunena configuration panel : docs.kunena.com/index.php/How_to_integra...tem_UddeIM_in_Kunena
16 years 6 months ago #48612 by bigmike0601
Done, Thank you! I should have checked the kunena config first. Didn't occur to me for some reason. Thanks again!!
