Question Kunena Horizontal / Verticle Scroll Bar on Code Tags
  • C0n
  • C0n's Avatar Topic Author
  • Offline
  • Premium Member
  • Premium Member
  • Only the strongest will survive
16 years 6 months ago - 16 years 6 months ago #48239 by C0n
If you havnt noticed with Kunena it only likes to do horizontal scroll bars when you add in long lines of code to your post
i was woundering if perhaps theres a fix or a hack i can add in to make it shorten the post down so it uses horizontal and verticle scroll bars when i add in the code tags.
it could just be a template issue with the custom one im using im not sure maybe someone with more knowledge knows :D thanks for any help you can provide :)
if nobody knows what i mean i will provide a screenshot
Last edit: 16 years 6 months ago by C0n.
16 years 6 months ago #48241 by sozzled
I don't know if this is normal behaviour for Kunena or not, but I suspect that it is normal behaviour. If you have a long (wide) message, in order for the text to be displayed within the constraints of the [standard 400px] textarea width that you defined in your Kunena configuration settings , the page enables the auto-scroll feature incorporated in the Kunena default_ex CSS.
Even when you use the CODE tags, the autowrap feature, that breaks on a word boundary, still applies ... unless your line is very long without any spaces.
Does this help explain what's happening? :)
  • C0n
  • Offline
  • Premium Member
  • Premium Member
16 years 6 months ago #48242 by C0n
it does but i was more hopping someone would be able to point out a way i can add in a verticle scroll bar so you would have the feature to scroll along and up / down rather than just along the post :p but il try this configuration setting you pointed out and reply with any fixes it has :)
  • C0n
  • Offline
  • Premium Member
  • Premium Member
16 years 6 months ago #48243 by C0n
nope its the same :( i wounder if its something that will be in kunena 1.6
