Question there are no posts in this forum
16 years 7 months ago #46827 by nick2009
hello everybody
I ve been very busy in the last few days with an important "merge" of 2 different websites and forums.
I hope someone can give me a valid suggestion,otherwise I ll go crazy!
one forum is under KUNENA , one is UNDER PHPBB3
I ve spent many days... using scripts, converters etcetera.
the final result is that I got the databases merged and I see in phpmyadmin:
ALL USERS (from actual and previous forums) everyone with a unique ID
ALL CATEGORIES everyone with a unique ID
ALL POSTS everyone with a unique ID
If I try testing the DB with FIREBOARD I see all the posts, all the users, all the categories. Everything is fine!
If I test it with Kunena 1.5.11 I see only the categories, the "last post by", the number of posts, topics, views and time!
If I enter each of the forums (bot the old and the actual ones) I
see "there are no posts in this forum"
I ve tried to synch users, to recount stats... but NOTHING GAVE ME GOOD RESULTS.
PLEASE HELLLLLLPPPPP
THANKS
16 years 7 months ago #46828 by nick2009
sorry to bump it up.. but i need URGENT help!
16 years 7 months ago #46832 by xillibit
Your problem is more complicated that it sound, because you try to merge two databases into one, so there will be conflict on ID. Actually, there are no solutions to do these kind of things, you can migrate from PhpBB, but you can't merge phpBB datas into Kunena.
16 years 7 months ago - 16 years 7 months ago #46833 by nick2009
hi I m 100% sure there are no conflicts on IDs
neither on categories, nor on users, nor on messages.
I ve taken care of that.
I ve checked the DB everything is fine.
Indeed all was working perfectly with Fireboard component I used during migration.
after upgrading to Kunena 1.5.11 I see no posts.
I think it is something so fool not to be noticed by myself after all these hours on the pc.
maybe mathias has the solution.
Last edit: 16 years 7 months ago by nick2009.
16 years 7 months ago #46839 by nick2009
just to confirm my theory.
if I use fireboard all users, posts, categories are shown correctly.
if i migrate to kunena i see no posts.
please help.
16 years 7 months ago #46887 by Matias
So it looks like that your imported database has some flaw (field with wrong value) which prevents it from working in Kunena.
Go first to the backend and try to sync users and forums/categories. If it does not help:
Easiest and fastest way to find out what, is to create topic with some replies in phpBB and import it, then do the same inside Kunena and compare differences in phpmyadmin.
