Question Can not preview...
16 years 6 months ago #46005 by aic
Replied by aic on topic Re: Can not preview...
Ok, I already PM to you
16 years 6 months ago - 16 years 6 months ago #46006 by Cerberus
Replied by Cerberus on topic Re: Can not preview...
your site is very very broken, the only way i can see to fix this is for u to completely reinstall your whole site from scratch and start again.
From testing i found that even your main joomla home pages does not even work and i can see CSS and JS errors all over your site.
steps required:
1. backup database and custom templates
2. completely delete site
3. install joomla ( check for errors )
4. install kunena ( check for errors )
5. install uddleIM ( check for errors )
6. add your Custom template ( check for errors )
after you have confirmed that all is working with the above basic setup then you can start to install any other custom modules and plugins ONE by ONE and checking for errors as you go, if any do appear then remove the last thing you install as that is the course of your issues.
NOTE TO OTHERS: this error is NOt related to kunena in anyway and is related to a very unstable Joomla installation.
Regards Cerberus
P.S. Please remember to delete any test logins made to help me test your site for security reasons
Last edit: 16 years 6 months ago by Cerberus.
16 years 6 months ago #46008 by aic
thanks for you help
16 years 6 months ago #46011 by Cerberus
your very welcome.
16 years 6 months ago #46298 by aic
Hi, I followed with the suggestion from Cerberus and the problem gone!
I have one question, I found an error like:
jQuery.kunena_cookie is not a function
www.xxx.com/components/com_kunena/templa...lt/js/kunenaforum.js
How can I fix this? pls suggest me.
Mega Thanks!
16 years 6 months ago #46344 by sozzled
Replied by sozzled on topic Re: Can not preview...
Does this "jQuery.kunena_cookie is not a function" issue have anything to do with the "preview" matter that you discussed earlier? If it doesn't please open a new discussion topic. As Cerberus stated earlier, it's not a good idea to hijack someone else's topic and then go off on a tangent into something else. It only confuses the original subject and makes it difficult for other people to search for the answer to their problems. Thank you. :)
