Question Database errors in my Kunena forum
16 years 7 months ago #44519 by standarddamage
Sorry for the double-post, but I just found something else that might help.
I was scouring both my front and back-end of the site. When I clicked on the Categories section of the back end, it gave me this:
DB function failed with error number 5 Out of memory (Needed 20971492 bytes) SQL=SELECT c.*, c.checked_out as checked_out_contact_category, g.name AS groupname, u.name AS editor, COUNT( DISTINCT s2.checked_out ) AS checked_out_count , z.title AS section_name FROM jos_categories AS c LEFT JOIN jos_users AS u ON u.id = c.checked_out LEFT JOIN jos_groups AS g ON g.id = c.access LEFT JOIN jos_content AS s2 ON s2.catid = c.id AND s2.checked_out > 0 LEFT JOIN jos_sections AS z ON z.id = c.section WHERE c.section NOT LIKE "%com_%" AND c.published != -2 GROUP BY c.id ORDER BY z.title, c.ordering LIMIT 0, 20
16 years 7 months ago #44520 by Cerberus
did this get sorted cause looks fine to me i dnt see any errors???????????
16 years 7 months ago #44521 by standarddamage
sozzled wrote:
So, for each of the 17 Kunena database tables (they have the prefix jos_fb_*) you have gone to the "operations" tab in phpMyAdmin and run the various table maintenance utilities: Check table, Analyze table (and possibly Repair table) and you haven't detected anything or nothing has changed?
I ran those operations under the "Structure" tab. Is that what you're referring to?
And, yes, everything came back normal.
16 years 7 months ago #44522 by standarddamage
Thank you for the heads up on that. I'd say it fixed itself, but I know better.
I'm off to go strangle my host. I sent off a support ticket, and they said it was on their end and apologized for any inconvenience.
Sozzled, as always, thank you so much for your help. Even if the problem didn't have anything to do with us, I at least learned a few more things about the database. :)
16 years 7 months ago - 16 years 7 months ago #44523 by sozzled
Likewise. I also just visited the links posted in the original message and there were no errors.
This looks like a problem with the server and not with Kunena. I'm moving this from Support to Common Questions!
Would you like some help strangling your webhost? :laugh:
Last edit: 16 years 7 months ago by sozzled.
