Question How to show modules on specific forum categories?
16 years 8 months ago - 16 years 8 months ago #42608 by theprofessor
EDIT: I apologize, I believe I should have put this in the Support forum. Please disregard and I have posted in correct forum.
I am trying to show modules (example, kunena_announcement) on just a particular forum category.
Is anyone able to help with a solution to this?
Thanks in advance!
Last edit: 16 years 8 months ago by theprofessor.
16 years 8 months ago - 16 years 8 months ago #42638 by sozzled
I appreciate that it is sometimes difficult to know where to post questions.
The Support category is for "technical support with Kunena ... [and] is mainly meant for bug reports and solving issues", that is issues relating to the core, unmodified, Kunena "product". I think that your question is a more general Joomla-related matter (or it could be considered a question of how you want to design your website) in which case this "Common Questions" or Templates and Design categories would seem to be quite appropriate.
For these reasons I have removed your later message posted elsewhere. :)
I am not quite sure I understand your question. Do you want to know if it's possible to show the general forum announcement only on a specific forum or category. Is there something particularly wrong with having a general announcement appear on all your forum pages? Have you considered modifying the category or forum description to tailor the "announcement" to an individual forum or category? That's how I would go about it.
Last edit: 16 years 8 months ago by sozzled.
16 years 8 months ago #42643 by theprofessor
Sozzled, thank-you kindly for the explaination of where to post this type of question.
Perhaps this is a Joomla question...I was hoping someone might have a hack to do this since it does involve Kunena module positions.
To clarify, here is hopefully a better explaination of what I want to do:
Let's say I have (2) forum categories: "Main" and "Support". Now let's say I create (2) different modules, and I ant to display both modules in the module position 'kunena_announcement'. I want one module to display in "Main" and the other to display in "Support".
16 years 8 months ago #42647 by toohinc
If you find how this can work please let me know, i need this also. Thank you.
16 years 8 months ago #42649 by @quila
for doing what you ask is not possible to publish modules in the kunena_announcement position. You need to load modules based on Category ID.
