Question Simple way to change default avatars and icons.
16 years 8 months ago - 16 years 8 months ago #41367 by julies
I think this would be great as I am having no luck changing mine. No matter what I do, the default always shows. It wold be great ifwe could edit them like we can the emoticons.
Last edit: 16 years 8 months ago by julies.
16 years 8 months ago - 16 years 7 months ago #41590 by fullstackedpoker
I have my avatars set up to use JomSocial avatars. So my avatar location is different. But I did a quick glance at my files. The default avatar files for Kunena are located at [strike]root/componenents/com_kunena/kunena.files.distribution/avatar[/strike] , they are named nophoto and s_nophoto. I did not test this, but i assume changing these files will change the default avatar in Kunena. Hope this helps.
Last edit: 16 years 7 months ago by @quila. Reason: wrong information
16 years 7 months ago #44779 by julies
I have changed the no photo and s-no photo and uploaded them to the proper place. I still am getting the old default avatar. is there a cahe or something that I can delete so that my new default avatars will show. Even when I delete the no photo default avatar completely, it still shows.
16 years 7 months ago - 16 years 7 months ago #44781 by @quila
you need to change the photo in the folder
root / images / fbfiles / avatars /
and not how is described in the post above.
16 years 7 months ago #44801 by julies
Thanks, It worked!
