Question Forum not displaying correctly
I am new to Joomla and have a problem.
I have just installed the Kunena Forum.
As you can see from the picture, the menu on the left-hand side is stopping the forum using the full site width.
Does anyone know how to remove the menu from the left-hand side, but only for the forum page?
Regards
Dennis
For to this, you need to unpublish the concerned menu around of your forum (position left and right), but only for the forum page.
So, edit the modules concerned and in menu assignement unselect the thing related to all.
You, need to this for all modules that you want to remove. I hope that this is clear.
You can read this too : docs.kunena.com/index.php/How_I_can_get_..._Forum_in_my_site%3F
Sadly I am new to Joomla and dont know how to do that.
I have also read the information at the url you posted but I am still non the wiser :blush:
Regards
Dennis
If you want that your Kunena Forum take all the page and remove some modules around the forum, you need to edit the modules concerned and in menu assignement unselect the thing related to all.
By example, for the module "User Menu", when you are in joomla! backend go in Extensions -> Module Manager and there choose the module "User Menu" and hit the button edit. Then, in menu assignement part, choose "Select Menu Item(s) from the List", in the list deselect the Kunena item or just choose the page where you want see this module, but don't choose Kunena item. Reproduce, this procedure for all modules that you want remove.
docs.kunena.com/index.php/Image:Remove_module_forum_page.png
I now have it working
Regards
Dennis
