Question Bugging error Help me!
16 years 10 months ago #36125 by nut
Bugging error Help me! was created by nut
Parse error: parse in C:\WM\www\...\components\com_kunena\lib\kunena.config.class.php on line 65
where change bug ?
16 years 10 months ago #36126 by nut
Replied by nut on topic Re:Bugging error Help me!
This is on line 65 abstract class CKunenaConfigBase
16 years 10 months ago #36127 by xillibit
Replied by xillibit on topic Re:Bugging error Help me!
What kunena version do you using ? Do you have changed something in this file ?
16 years 10 months ago #36150 by nut
I use kunena version 1.5.
I don't have change code or file.
I install com_kunena_v1.5.8_stable_b1863_2009-12-18 finish.
I click function components. I will see kunena forum.
I click its. it will show Parse error: parse in C:\WM\www\...\components\com_kunena\lib\kunena.config.class.php on line 65.
I don't will change or edit where?
16 years 10 months ago #36156 by xillibit
Try to re-upload on your server the file components\com_kunena\lib\kunena.config.class.php
16 years 10 months ago #36214 by Matias
Replied by Matias on topic Re:Bugging error Help me!
I've seen this before, too. Sometimes Joomla installer cuts file into half. No idea why it happens..
