Question Problem with replies to threads!
16 years 11 months ago - 16 years 11 months ago #35060 by stream
When Im logged in and write a reply to a thread the reply dont show up at all.
But when Im not logged in I only can see the reply, not the original post!
What could be wrong? I have edited some code in Kunena. Could I have deleted some important code that should show both the original post and the replies at the same time? I know that I have added "display: none" to some text in the css code.
Last edit: 16 years 11 months ago by stream.
16 years 11 months ago #35067 by Matias
You should try latest Kunena without your changes and by using default_ex, first. It tells you if your modifications or custom template has any issues.
16 years 11 months ago - 16 years 11 months ago #35071 by stream
Thanks for the answer.
I have the latest Kunena. But if I use default_ex my changes wont show right? I have done alot of changes that made my forum/site better looking. So can I see any other way what could be wrong? Or can I choose to have default_ex and see whats wrong and then change back to my template of Kunena?
16 years 11 months ago #35076 by Matias
Yes, your changes wont show. But I didn't mean that you need to change your template, I just wanted you to make a quick (few minutes) test that the issue is not in the default_ex.
So yes, this test will help you to hunt the bug. If it is in your changes, finding it should be pretty easy. And if it's in official release, we would be able to fix it.
BTW: did you make your changes before upgrading to later version of Kunena? If so, you need to adapt your changes to the new version (I would wait for K1.5.8) or downgrade back to older Kunena release and do the adaptation later.
16 years 11 months ago - 16 years 11 months ago #35081 by stream
I didnt upgrade to a later version of Kunena. I installed 1.5.7 directly when I created the forum a week ago.
Im gonna look in the default_ex and see whats different to my files. Hope to find the answer to this :)
Edit: I found the answer! I replaced my view.php with the view.php that was in the default folder. And now the replies show!
16 years 11 months ago #35088 by Matias
That file in default folder is deprecated, please use view.php from default_ex instead.
