I'm fairly new to Kunena so forgive me if this is a repeat question but I couldn't find it using the search tool.
I have certain forums off limits to members of lower ranks to post in and see discussions. I can hide these forums from view easily enough, but when someone clicks on the 'recent discussion' tab they can see the conversations going within the forum even though it is hidden and off limts to them.
More specifically: I give a registered user lower rank of 'author' and another registered user a higher rank of 'publisher'. The rank of publisher can see all of the forums available but the rank of author should only be able to see certain forums. When I created a test user and gave them a lower rank I found that I could only see the forums available to me as I expected. However, when i clicked on the 'recent discussion' tab I could see conversations going on in forums that I should not have access too. I couldn't post replies in the restricted forum but I could see the threads.
How do disable or configure the 'recent discussion tab' to not do this.
Did you do this with only one test user? Forum permissions are cached and cleared if changes happen in forums. But they are not changed right away when you change users group in Joomla itself.
K1.5.8 will have tool to do cache clearing, but now you will need to save the user in Kunena in order to get permission cache cleared.
