Question separate kunena users from cb users
16 years 11 months ago #34531 by davidmara
Hi guys,
I have some questions...
I have Community builder and kunena installed with cb kunena forum integration plugin.
Now I found out that everybody who register using kunena regsitration is automatically registered to community builder but this what I dont want. I want users who registered to community builder to be added as kunena users but I need people who use kunena registration to be not added as CB users. Is it possible to do that ?
Second question I have there is kunena word as first thing (Kunena-Main forum). How can I remove word kunena and left only Main Menu or other named main menus...
many thanks in advance for help ...
Dave
16 years 11 months ago #34684 by Matias
If you have CB integration turned on, Kunena does not use it's own profiles -- it uses profiles from CB. And because of that, all Kunena users must have user info in CB, otherwise they cannot be users in Kunena.
You can turn integration off, that way Kunena uses it's own profiles.
To remove Kunena word, you need to (re)name your forum in Kunena configuration.
16 years 11 months ago - 16 years 11 months ago #34699 by davidmara
HI Matias,
thanks for reply but I need a little different thing.
1) I need registered community builder users to be automatically registered as kunena users. At this point its okay - this is working
2) I need if somebody register to forum to be NOT automatically added as community builder registered user. And this is what I need figure out how to do... because now if somebody register to kunena than is registered also to community builder... and thats what i dont want..
If I turn integration off than kunena users will be not registered as CB users but also CB users will be NOT registered in kunena ... so that the problem...
I need both ponts 1 and 2 to be active in same time...
An recommendation how to do it ?
thanks in advance
Dave
Last edit: 16 years 11 months ago by davidmara.
16 years 11 months ago #34703 by Matias
Yes, that was exactly what I was trying to tell you. You can have only both or independent registration.
You may be able to do this by changing registration link in CB integration to point Joomla instead of CB. The issue in that solution is that your Kunena profile is your CB profile, so once you edit it, you become CB user.. So I wouldn't count that as solution..
Another thing you may try, is to have integration turned on in CB, but not in Kunena. It will have it's own issues, but may (or may not) work.
My point is that profile integration means just that: if you turn it on, Kunena doesn't use it's own profiles anymore -- it takes that profile from CB. That is why 1) works like it does. Without integration, there's no integration at all..
