Question Translating Kunena for logged in users
16 years 11 months ago #34104 by matawest
Hi!
I've installed the Swedish translation for Kunena and it works fine, as long as user status i Guest. When I log in as admin the forum suddenly turns back to English version. From what I have been able to check out there is no other part of the Joomla directory than admininstrator/components/com_kunena/language where the language translation file should be put.
Best,
Matt
16 years 11 months ago #34106 by xillibit
Maybe you have not set swedish in joomla backend -> language mangager -> front-end
16 years 11 months ago #34107 by matawest
Thanks for the suggestion! "Unfortunately" both front- and backend are set to swedish. This really puzzles me.
16 years 11 months ago #34114 by xillibit
If you have put your swedish file in admininstrator/components/com_kunena/language , try to remove the file kunena.english.php.
16 years 11 months ago #34117 by matawest
I renamned the english language file to see what happened. Now it is obvious that when logged in this file is in use. The page got messed up :-) Could it have anything to do with the image folder? Perhaps the system is reaching for the english images when logged in?
16 years 11 months ago #34124 by xillibit
I'am a bit confused, it's the language strings which are not in swedish are the images (new thread, replay, quote...) ?
