Question Using another SQL DB for Kunena, from Joomla
  • VinceViag
  • VinceViag's Avatar Topic Author
  • New Member
  • New Member
16 years 11 months ago #33847 by VinceViag
Can someone please point me to info, on how to use a different SQL DB for Kunena, from the main one Joomla is using? I have 3 x 150 MB DBs available.
TYIA
VV
16 years 11 months ago #33914 by Matias
You need to have huge site and/or over 100 000 messages to get over that limit. And at that point you will need a better (virtual) server anyway..
Joomla does not save files into database, only content.
  • VinceViag
  • New Member
  • New Member
16 years 11 months ago #34392 by VinceViag
Replied by VinceViag on topic Re: Using another SQL DB for Kunena, from Joomla
Yes TY,
But I would like a separate DB for Joomla and Kunena. Surely this must be possible?
WM
16 years 11 months ago #34405 by xillibit
This is not possible because kunena use the database layer from joomla! like other components into joomla! and Kunena needs some tables from joomla! by example jos_users to work.
It's strange that your hoster propose to you 3 differents databases with 150 Mo each.
