Question Configuring visibility and access for a "Authors and above" forum
  • maggix
  • maggix's Avatar Topic Author
  • New Member
  • New Member
17 years 6 days ago - 17 years 6 days ago #33434 by maggix
Hello, I am a long time Fireboard user that yesterday found some time (at last!) to upgrade a fairly large FB forum to Kunena.
Nothing to say about that: speed and polishness are amazing.
However, there's a strange functioning of a feature that maybe you can help me solve.
I have a forum that I want to be only for Authors and above (Authors, Editors, Publishers and then Managers, Admins and Super Admins).
In Fireboard, I got that to work just by setting "Authors" in the public access and then leaving the "Administrator access" blank. However, in Kunena , with this configuration the forum was hidden to the Backend Users.
I read the Kunena documentation page, and by those info I set this configuration:
Public: I clicked on Authors and set YES to the "Included Child Groups"
Admin: I selected Managers and set YES to the "Included Child Groups"
However, this does not work for Administrators, it works only for Authors,Publishers and Editors... Administrators can't see the forum with this setup, and that's strange
I could not find a configuration to obtain what I want, which is:
Forum HIDDEN for unregistered users
Forum HIDDEN for registered users
Forum VIEWABLE and ACCESSIBLE by all users above the Author level (included)
Can you link me a post that deals with this setting, or suggest anything?
Thank you in avance
Giovanni
Last edit: 17 years 6 days ago by maggix.
17 years 3 days ago #33650 by Matias
It should work just like in FB (well, except that there are some bug fixes). Both ways should work..
BUT there is one exception: if you change user group, you need to refresh cache to get the new permissions to work. K1.5.8 will have special option to do this, but in older releases you need to save that user in Kunena or save any category (which will clean cache from all users).
Did this help you?
  • maggix
  • New Member
  • New Member
17 years 3 days ago #33688 by maggix
Hello, thank you for your reply!
For the moment, I just choose 1 item for each permission group (Publishers + Super Administrators) and ofc it works.
However, you just explained me why, on the tests I made, I had lots of troubles because I tested the configuration with only 1 user that I kept switching from a group to another....
I'll keep it in mind for next time :)
