Question How to exclude a specific category posts from Recent Discussion?
17 years 3 weeks ago #31932 by Sahil
i want to exclude a specific category new topics and replies from Recent Discussion tab.. is there anyway to do that? any help would be really appreciated.
thanx
17 years 3 weeks ago #31940 by etusha
the only way to do that is change the
/components/com_kunena/template/default_ex/latestx.php
17 years 3 weeks ago - 17 years 3 weeks ago #31945 by Sahil
Thanx etusha for reply..
can you please specify the code which i need to edit. i would be really thankful. i just want to remove 1 category posts.
edit: i found this code for include categories.
$catlist = array();
is there any code to simply exclude 1 category instead adding all category numbers. and then i have to edit everytime to include a new category.
thanx
Last edit: 17 years 3 weeks ago by Sahil.
17 years 3 weeks ago #31989 by Matias
There is configuration setting for this:
Recent Post Settings > Show Category
Unfortunately you need to do in another way: list every catid you want to show.
17 years 3 weeks ago #31997 by Sahil
Ok..
Thanx for the help..
16 years 10 months ago #37406 by kapearl
I'm using the default_x template on K1.5.8, J1.5.15, trying to show only certain post categories and the Show Category settings are ignored on the Recent Discussions tab. I've set my cats I want to display like this: 11, 73, 1, 25, 46, 90, but all posts still display. And the other settings like Show Hits, author and so on also don't change either when I change the setting. I've cleared the cache, changed templates but that doesn't seem to get the Recent Post Settings to kick in.
