Question Help: newbie here to Kunena. I wiped out categories? how to reinstall fresh?
16 years 8 months ago #30580 by claydoctor
I tried to configure Kunena, and somehow I think i wiped out the initial categories list. I cannot create a new category, only a new forum. I uninstalled the component, and re in stalled the zip file, but the new install defaults to the old set up. Weird. And my old forums just appear, as well as all my other data (not much). Not good. Could someone please tell me how I can start fresh and do the set up the right way (right- read the documentation all the way thru - I know). I cleaned all cache files. Thanks.
16 years 8 months ago #30583 by etusha
do a normal uninstall
and remove jos_fb_* table at mysql DB
16 years 8 months ago #30588 by claydoctor
checking my mysql DB, no file "jos_fb_* table" exists after uninstall completed. (not sure - didn't check if it existed before uninstall). any other ideas? Appreciate any help here. Thanks.
16 years 8 months ago - 16 years 8 months ago #30670 by jeff_j_dunlap
Due to some problems, I want to delete all Kunena tables and do a fresh install.
Is it safe to assume then that all Kunena tables begin with jos_fb_ ?
Thank you :S
Last edit: 16 years 8 months ago by jeff_j_dunlap.
Time to create page: 0.310 seconds
