kunena has made it very easier to integrate with joomla.thanks for this wonderful work. but some of the bugs are really annoying. i changed every possible configuration for the post to appear first post first, at kunena control panel at backend and at user profile settings. even when i log in as super admin the problem still exists.
here is the link to this dysfunctional post order.
yes. its now set into default_ex template. but the problem still exists?? on some threads it works according to the setup. but on others like the link i showed, it doesnt work?
You can also order posts in reverse order, and there is a configuration setting for it -- but for old users the configuration setting has no effect. Old users need to change the order by themselves as there is no "use default" option for them.
