Important Filter for naughty words
17 years 2 months ago #29229 by rocket
I was wondering if my JomSocial word filter would also work for Kunena?
If not can anyone suggest a word filter for Kunena, or the entire site? Maybe one that could import bad words from a csv or exel file?
Also, does anyone know of anywhere i could get my hands on a list that could be copied and pasted or imported csv into an extension?
Thanks so much.
17 years 1 month ago #29935 by lonnewolf
I don't use JomSocial, so I don't know if its filter works on Kunena. But I know ReReplacer works fine for the entire Joomla site, including the Kunena forum.
17 years 1 month ago #29945 by rocket
Replied by rocket on topic Re:Filter for naughty words
Got! Works like a charm1
Thanks!
17 years 1 month ago #29966 by woonydanny
hmmm.... it would be good if we could somehow use the JomSocial word filter. Anyone tried this yet? Does it work in kunena as a joomla plugin?
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
17 years 1 month ago #29996 by rocket
I believe the Jomsocial word filter only works on the JS core, but not sure. It would make sense that it would work on everything it integrates with, because there would only be the profile part to filter, and maybe MyBlog.
I'm using ReReplacer now and it covers the whole site. You can even set a filter for fixing bad code, such as domready. Very cool. This was a big issue with my site since it is family oriented.
17 years 1 month ago #30031 by woonydanny
offtopic: what did you replace domready to with rereplacer?
Time to create page: 0.249 seconds
