Question Problem Forum border
17 years 2 months ago #28458 by dauf
Problem Forum border was created by dauf
hello there..i've problem with the left border of my website..
it's not visible, whereas the right border is visible..
how can i change it??
[IMG
  • cXc
  • cXc's Avatar
  • New Member
  • New Member
17 years 2 months ago - 17 years 2 months ago #28459 by cXc
Replied by cXc on topic Re: Problem Forum border
Open your chosen templates template.css file and look for these css id's and classes and add border-left css ...
#Kunena th.fb_sectiontableheader
#Kunena td.fb-msgview-right
#Kunena td.fb-msgview-right-b
That's just guessing though based on the default ex template those are the ones to look for, if your site was live I could have Firebugged it and gave you the line numbers and everything ...
~cXc~
Last edit: 17 years 2 months ago by cXc.
17 years 2 months ago #28462 by dauf
Replied by dauf on topic Re: Problem Forum border
thanks 4 ur reply..
i already add all css at the place u stated above, but still there's no border on the left side of my forum..
huhu..no live site yet..still working on localhost..
  • cXc
  • cXc's Avatar
  • New Member
  • New Member
17 years 2 months ago #28472 by cXc
What template are you using?
17 years 2 months ago #28476 by dauf
celebsplazza...anything to do with joomla template??
  • cXc
  • cXc's Avatar
  • New Member
  • New Member
17 years 2 months ago - 17 years 2 months ago #28478 by cXc
Its possible but I doubt your site template would override your Kunena template css. I'll see if I can track down a copy of this template and install it so I can Firebug it.
[EDIT] That is your Kunena template name right?
Do you have a link where I can download the template you use with Kunena, set in Kunena Config? [/EDIT]
