Question Problem with uploading images
17 years 2 months ago - 17 years 2 months ago #28369 by X-Bumble
Spotted something else - but you may know about this.
I've read through the bug fix for having images show and that works a treat. I also note that you can't preview an image as yet.
The problem I have is that if you hand code [img]cxcxccx[/img] into a new post with nothing else added, it will display happily.
However, if you click on the 'Select image file to attach' button and then select the file but have nothing else in the post, the forum throws it back saying that nothing has been entered in the post and to use the back button to add some content.
I assume the the first method works as the system picks up you have typed in the bbcode, whereas using the upload button it does not detect any content as being added and thus throws up a null value.
*** I've just realised I've posted this in the wrong place. It should be for 1.5.5. Sorry - it's 1.15am and my brain has shut down ***
Last edit: 17 years 2 months ago by X-Bumble.
17 years 2 months ago - 17 years 2 months ago #28370 by @quila
Hello X-Bumble,
when you want to insert only image in the post you must click to button "[img]" look image [img]http://www.kunena.com/media/kunena/attachments/legacy/images/ima.png[/img]
P.S. The post was moved by moderator to appropriate area, don't need to recreated another one
Regards
Last edit: 17 years 2 months ago by @quila.
17 years 2 months ago - 17 years 2 months ago #28377 by X-Bumble
OK, got it to work - thanks for that.
My users will never work that out without some instruction near the buttons. I'll have to add some instructions in the box to the right of it.
Cheers!
