Question Codes are not Working On my Websites , Am i Missing something
17 years 3 months ago - 17 years 3 months ago #25418 by nauman
Hello All
Once again a silly Question
Codes are not working on my website , Like Quote , Code, Bold, I ,Noone is working, If i add manually , it just shows up like,
<strong>Welcome to our websites!</strong>
All settings seem to b ok
Also Another Quick Question,On My Main Forum page, It just says , Categories--Website name
I wana off this option, As this th ing also happens here on kunena, It says, Categories First, then Kunena
I want title as, first site name, then Categories, or Latest Discussion
Need Help
Regards
Last edit: 17 years 3 months ago by nauman.
17 years 3 months ago #25419 by nauman
For my second Question, There is another thread, but ended without any Result
Any Experience
www.kunena.com/forum/136-templates-and-d...itle-in-kunena-forum
Regards
17 years 3 months ago - 17 years 3 months ago #25425 by sozzled
Let's start with the basics: Kunena doesn't do anything with standard HTML tags (those things wrapped in "angle brackets", like <strong>, for example). Kunena uses boardcode (sometimes referred to as BBcode ) which employs "tags" wrapped in square brackets. This is better discussed in the article A basic forum help page for beginners in the Wiki.
Therefore, if you try to use
this will display as
If you use
[b]Welcome to our websites![/b]
it will show as
Your second question:
I wana off this option, As this thing also happens here on kunena, It says, Categories First, then Kunena
I wrote some tips on how to achieve that in the discussion that you referred to in your second posting. Here is the answer (updated for K 1.5.4):
1. For the categories: edit the file ../components/com_kunena/templates/default_ex/fb_layout.php at line 68
$document->setTitle(stripslashes($objCatParentInfo->name) . ' - ' . stripslashes($obj_fb_cat->getName()) . ' - ' . stripslashes($fbConfig->board_title));
To:
$document->setTitle(stripslashes($fbConfig->board_title) . ' - ' . stripslashes($obj_fb_cat->getName()) . ' - ' . stripslashes($objCatParentInfo->name));
Change at line 82
$document->setTitle(stripslashes($obj_fb_cat->getName()) . ' - ' . stripslashes($fbConfig->board_title));
To:
$document->setTitle(stripslashes($fbConfig->board_title) . ' - ' . stripslashes($obj_fb_cat->getName()));
Change at line 126
$document->setTitle($obj_post->subject . ' - ' . stripslashes($fbConfig->board_title));
To:
$document->setTitle(stripslashes($fbConfig->board_title) . ' - ' . $obj_post->subject);
2(a) For the my discussions: edit the file ../components/com_kunena/templates/default_ex/latestx.php at line 135
$document->setTitle(_KUNENA_MY_DISCUSSIONS . ' - ' . stripslashes($fbConfig->board_title));
To:
$document->setTitle(stripslashes($fbConfig->board_title) . ' - ' . _KUNENA_MY_DISCUSSIONS);
2(b) For the recent discussions: change the same file as 2(a) at line 148
$document->setTitle(_KUNENA_ALL_DISCUSSIONS . ' - ' . stripslashes($fbConfig->board_title));
To:
$document->setTitle(stripslashes($fbConfig->board_title) . ' - ' . _KUNENA_ALL_DISCUSSIONS);
Last edit: 17 years 3 months ago by sozzled.
17 years 3 months ago #25427 by JBHawaii
Sounds like a rokcandy issue, do you by chance use Rocket theme template?
Mahalo,
JBHawaii
17 years 3 months ago - 17 years 3 months ago #25429 by markjones
I am getting a similiar issue with BOLD.
If I mouse over the bold icon on my installation, it shows <strong>... see img attached
When I mouse over your bold, it is correct.
Yes, I am using a rockettheme template (if that helps)
Last edit: 17 years 3 months ago by markjones. Reason: added picture
17 years 3 months ago #25432 by sozzled
@markjones: Ah! :lol: The dreaded RokCandy-plugin-stuffs-up-Kunena disease! See the discussion BBCode not working .
