Question Is there a way?
17 years 4 months ago #24662 by philman401
Is there a way? was created by philman401
Is there an instruction somewhere on how to install kunena manually?
17 years 4 months ago #24666 by Lintzy
Replied by Lintzy on topic Re:Is there a way?
The only way to install Kunena is over the joomla backend -> extensions-> installation routine.
17 years 4 months ago - 17 years 4 months ago #24689 by xillibit
Replied by xillibit on topic Re:Is there a way?
What do you want do a manual install ?
you can copy kunena files into the right directories including (administrator/components/com_kunena and components/com_kunena), into the kunena archive in the directory install you have the file kunena.install.upgrade.xml with some sql queries and in kunena.install.php. But you need to do some others queries for set the components into joomla, but i don't know these joomla queries.
Last edit: 17 years 4 months ago by xillibit.
17 years 4 months ago - 17 years 4 months ago #24694 by Lintzy
xillibit, of course, it is always possible to upload files. But that is not the complete installation.
Regard this post of fxstein:
fxstein wrote:
Lintzy wrote:
Did you try this?
But you can ftp the unzipped package into a seperate folder on your server and use the Joomla option to install from an existing directory.
I'd second that.
Use the install from folder option in Joomla.
Upload the entire package to a folder of your choice on your server. Unzip or untar it.
Use the Joomla installer to install from there.
No it is not possible to install by hand. Way too many files, settings, Joomla internal settings and entries, database setup, version control that must be handled by the installer and our install code.
Not even we developers install it by hand because it is too complex and failure prone.
www.kunena.com/forum/135-solved-installa...l-install-help#20587
Last edit: 17 years 4 months ago by Lintzy.
