Question Mod controls: How to select multiple posts and split from threads
17 years 4 months ago #23951 by gthang
In Kunena as a mod, how do you select multiple posts in a thread and split them off to create a new thread. I can't figure this out at all. The only option I see is to manually split off 1 post at a time and then it creates 1 new thread, then I'd have to merge those all individually.
Is there a fast way to do this? I mean if I had to split off say 40 posts from a thread to make a new thread for it (say offtopic posts), it seems like a lot of headache and work to do.
Thanks for any help
17 years 4 months ago #24051 by woonydanny
not sure, but i think the moderator tools are getting reworked in the upcoming Kunena 1.6
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
