Question Public/Admin access level
- Chrysanthos
- Junior Member
- Chrysanthos
- Junior Member
what should i choose?
You haven't said what you want. The settings shown in your illustration will work for most typical Kunena applications where you want visitors to be able to read all the messages posted in the forum (assuming that's what you want them to be able to do). If you only want registered members (or authors or reviewers or publishers) to be able to read messages, then you should select a user type for Public Access Level that suits your needs.pls help?
You should select something for Admin Access Level. Super Administrator will work.
I wrote some tips on this subject at docs.kunena.com/index.php/Configuration
- Chrysanthos
- Junior Member
- Chrysanthos
- Junior Member
