Question Merge and split in Kunena 1.5.4
16 years 11 months ago #23439 by jose
Hi
I would like to know if merge and split works OK in Kunena 1.5.4.
I just installed this version in test site but it does not show split button.
In version 1.0.9 (the last I installed) there were bugs with merge and split functions.
16 years 11 months ago #23441 by xillibit
On Kunena 1.5.4 the function merge works witout any problems, but the function split is disabled on Kunena 1.5.3, 1.5.4, 1.0.11 because it might break threads.
This is explained here : docs.kunena.com/index.php/Kunena_1.5.4_Read_Me#Known_issues
16 years 11 months ago #23444 by jose
Thanks for you quick response
But how can I move an off-topic message to a new thread?
16 years 11 months ago #23459 by xillibit
Because the split function is disabled, you can't do this, the only way is to modify the information of post in the database, to put them in other place.
Time to create page: 0.254 seconds
