Question Register, Logout and Alerts
- Our application has single-sign-on so that users can simultaneously login to the Message Board, their Back Office, and to other components of the site. Is there a way to change the "Register" link in Kunena so that it directs users to our package signup page rather than to a page that only allows them to register for the forum?
- Is there a way to remove the "Logout" link within Kunena? (we already have one in the top header)
- When someone updates information in their Profile the "Information updated" alert covers up the tabs at the top. Is there a way to reposition those alerts or to disable them?
Thanks!
- You'll have to redirect from the standard Joomla registration to your package signup page. To do this you must edit the following file /components/com_kunena/template/default/plugin/profilebox/profilebox.php. Change the following (Line 157):
to<a href = "<?php echo $registerlink;?>"><?php echo _PROFILEBOX_REGISTER; ?></a>
<a href = "Place the register link here"><?php echo _PROFILEBOX_REGISTER; ?></a>
- Same file remove:
<a href = "<?php echo $logoutlink;?>"><?php echo _PROFILEBOX_LOGOUT; ?></a>
- Not sure about this - i haven't seen it - but if you find the css responsible (use firebug) add the code
display:none;
dd.message.message.fade
change to
this will move it uptop:0;
OR ADD
this will stop it from showingdisplay:none;
