- Thank you received: 201
Question language pack does not work
try with this
<?xml version="1.0" encoding="utf-8"?>
<!-- $Id: zh-CN.xml 129 2008-07-28 09:45:23Z protege $ -->
<metafile version="1.5.7" client="site">
<name>Simplified Chinese</name>
<version>1.5.7</version>
<creationDate>2008-09-10</creationDate>
<author>Joomla! Project</author>
<authorEmail>[email protected]</authorEmail>
<authorUrl> www.joomla.org </authorUrl>
<copyright>(C) 2008 Open Source Matters. All rights reserved.</copyright>
<license> www.gnu.org/licenses/gpl-2.0.html GNU/GPL</license>
<description></description>
<metadata>
<name>简体中文</name>
<tag>zh-CN</tag>
<rtl>0</rtl>
<locale>zh_CN.utf8, zh, zho, zhi, zh_CN, zho_CN, zhi_CN, simplified_chinese</locale>
<winCodePage>cp936</winCodePage>
<backwardLang>simplified_chinese</backwardLang>
<pdfFontName>gbsn00lp</pdfFontName>
</metadata>
<params />
</metafile>
Regards
the file you using for chinese is not for Joomla Native and Kunena 1.5.3
open your kunena.simplified_chinese.php file and replace this
attached is my chinese pack, pls kindly help me to check it,
and maybe i try to find the standard Simply-chinese pack for Joomla 1.5x native and kunena
you can attach if the file is a 120 kb max.
attach only kunena.simplified_chinese.php file or copy here the first 10, 20 line.
Regards
