Question FB Tables
Please check that your MySQL client and server version is greater than our minimum. You can do that by going Help / System info / PHP information (you've looked into there already)-
There should be mysql and mysqli. Check the one you're using -- it may be using old version.
php version: 5.2.6 (Required >= 4.3.9)
mysql version: (Required >= 4.1.11) (i changed this in the kunena install file)
Also I still have the forums avalible but the version it says is 1.07b
If you take responsibility to yourself, edit install/kunena.install.php line 32 to 0..
For some reason your mysql version is empty..
