Question problem on frontend
15 years 8 months ago #87535 by kristin
problem on frontend was created by kristin
I have installed Kunena 1.5 and I can see it in the backdoor but from the front end - I can't see it at all. I've set the menu to the correct link but still nothing. I just get an error that the page doesn't exist when I try to click on that menu item. Can anyone help??
Thank you.
15 years 8 months ago #87537 by sozzled
Replied by sozzled on topic Re: problem on frontend
We recommend that you use K 1.6.3 because it's easier to set up and you should not have those kinds of problems that you now have. I recommend that you read K 1.6 Installation Guide . Why not give it a go?
