Question K 1.5.3 jos_fb_whoisonline is marked as crashed and should be repaired
15 years 9 months ago - 15 years 9 months ago #86759 by Anomal
Help please!
Today at an input on a forum I receive the following message
Table './grizanov_sb/jos_fb_whoisonline' is marked as crashed and should be repaired SQL=INSERT INTO jos_fb_whoisonline (`userid` , `time`, `what`, `task`, `do`, `func`,`link`, `userip`, `user`) VALUES ('79', '1298444623', 'а�аЛаАаВаНаАб�','','','','/index.php?option=com_kunena&Itemid=70', '46.33.32.13', '1')
Further there is a table with references
Unfortunately the backup copy isn't present. Very much it would be desirable to receive council (instruction) as it is possible to solve the given problem without loss of the data.
The reference to a picture as the forum now looks.
[IMG
Installed version: Kunena 1.5.3 | 2009-06-15 | 1688 [ Spreek ] | php 5.3.1 | mysql 5.1.30-log
In advance thanks for the help
Last edit: 15 years 9 months ago by sozzled.
15 years 9 months ago #86763 by sozzled
Perhaps someone in the community might be able to assist you with this problem. It is my guess that you need expert assistance to recover the data. This problem is certainly beyond my skill to help you with.
Under these conditions I would normally advise you to recover your database from the last good backup that you made. However, you have already stated that you don't have a backup. Maybe your webhosting provider has one?
K 1.5.3! I'm sorry for you. You are 2 years behind with the software. I don't think we'll be able to help you with this problem I hope you get things sorted out.
