Question I'm not sure why when I click on the rules & help link on my forum
16 years 3 months ago #57812 by daprince
the rules takes me to this link...
rules
and the help link takes me to this link...
help
and it's showing some different text from an article I created on my site. I'm not sure why it's doing this. I didn't change anything in the forum component that I know about.
16 years 3 months ago #57819 by sozzled
This isn't normal. :huh:
The links are defined in the Kunena Configuration settings.
16 years 3 months ago #57828 by daprince
If I uninstall it and re-istall will I lose the current users i have on there?
16 years 3 months ago #57830 by sozzled
There is no need to uninstall Kunena. There does not even seem to be a need to re-install Kunena in your case. You should change two two settings I referred to in my earlier message:
Rules external page link
Help external page link
See docs.kunena.com/index.php/How_to_create_a_rule_and_a_help_page
16 years 3 months ago - 16 years 3 months ago #57870 by stgeorge
Simply enter you rules and help into Joomla Articles.
Create these two articles in Joomla not any other component ie K2.
index.php?option=com_kunena&task=showconfig#frontend
Set:
Enable Rules Page
to Yes
Set:
Show rules in Kunena
to Yes
Enter the Joomla article ID into the:
Rules Content ID
Set:
Enable Help Page
to Yes
Set:
Show help in Kunena
to Yes
Help Content ID
Never say Never. Anything is Possible!
winfoes.co.uk
Last edit: 16 years 3 months ago by stgeorge.
