Question How do I delete a user and their messages
Not only that, but I can't seem, to delete these messages even though I am logging in as an Administrator.
Installed version: Kunena 1.5.12
Are you having a problem with the message Delete button? Is the Delete button not visible as one of the moderator tools?yorview wrote: I can't seem to delete these messages, even though I am logging in as an Administrator.
They don't seem to go? You mean, the messages are still there on youe site after you press the Delete button? :blink:yorview wrote: The delete button is visible , but when I delete the messages they don't seem to go.
This is very strange and, to me, it seems that there's something else going on that we're not aware of. To guide you, please see K 1.5.x Support: Please read this first and There is only one endorsed and supported Kunena template ... default_ex
- What version of Joomla are you using?
- What Kunena template are you using?
- Do you see any error messages when you press the Delete button in trying to remove messages?
- Can you delete other posts or is the problem only related to one post?
- What can you tell me about your database? What version are you running, what is the collation method on all the tables named jos_fb_* ?
- What other third-party Joomla extensions are you running (that is, anything else you installed after you installed Joomla)? (Joomla extensions are: components, modules, plugins, templates and languages)
