Question Forum Post didn't appear
16 years 3 months ago #53844 by clairestrife
i have jomsocial 1.6 and Kunena 1.5 on my site. When my user post something on our forum, the post appear on jomsical activity stream, but the post didn't show on forum. Can anyone tell me the right configuration to fix this issue? :dry:
thank you :)
16 years 3 months ago #53855 by xillibit
Can-you give me the kunena version and kunena template that you are using ?
Is it possible to have a link to your site ?
The following user(s) said Thank You: clairestrife
16 years 3 months ago - 16 years 3 months ago #53892 by clairestrife
Sorry for causing so much trouble... :)
it's my site, AntheM-AsiA :lol:
the template which we use are template designed by my staff. i use kunena version 1.5.11
Our webmaster had been investigated the problem all day long, it's works well on safari, google chrome, firefox and safari.
but not work on internet explorer all versions :(
if there any configuration for internet explorer?:cheer:
again, sorry for causing so much trouble
thank you :):)
Last edit: 16 years 3 months ago by clairestrife.
16 years 3 months ago #53895 by sozzled
Internet Explorer, whether it's IE 6, IE 7, IE 8 or IE9 (and they're all different!), seems to require special attention when you're writing CSS. The default_ex template was designed by the Kunena project team to work with IE 6, IE 7 and IE8. If you use your own template then you'll have to make your own adjustments. Sorry, but that's just the way things seem to be.
If you upgrade to K 1.5.12 and use the default_ex template designed for K 1.5.12 (and don't change it) then you shouldn't have any problems ... but, of course, there are no guarantees in the world of open source software development, are there?
I looked at your website - it seems to work OK in FF 3.6.8 - but it really doesn't matter if it looks good when it doesn't work for the different browsers that your users have, does it?
My recommendation: upgrade to K 1.5.12 and use the unmodified default_ex template for Kunena even if only to see if it fixes your IE issues.
16 years 3 months ago #53904 by clairestrife
thanks for reply my messages :)
can you tell me how to upgrade to new version? must i uninstalled it first and install the new component?
Thanks a lot for the support, kunena is the best. we get rid from agora and choose kunena... :laugh:
again, sorry for causing you so much trouble :)
16 years 3 months ago - 16 years 3 months ago #53906 by sozzled
Replied by sozzled on topic Re: How to upgrade Kunena
No trouble at all! :) We're here to help you as best as we can.
Upgrading Kunena (from any K 1.5.x version) is easy: just run the upgrade procedure. Unlike many other Joomla components, there's no need to uninstall Kunena first. As always, of course, you should take a backup of your website just in case there's a problem with the upgrade procedure. It's all explained in the companion Wiki site: docs.kunena.com B)
Last edit: 16 years 3 months ago by sozzled.
