Question Kunena forum look help
16 years 4 months ago #52634 by danmc09
How do I totally uninstall Kunena?
I previously uninstalled Kunena via the administration panel. But every time I reinstalled Kunena it would some how use the same setup as the previous installation... i.e. same forum categories, posts, admins etc. They would all some how save even though I uninstalled then re-installed it!
Before that wasn't that much of an issue... Now it is...
This time I went ahead and installed it and my forum would look like this...
As you can see... When I click on the forum link on my forum my website looks like the above... It removes my template from my forum and website...
I tried removing the Kunena' jos_ entries in phpmyadmin after an uninstall but that didn't make a difference.
16 years 4 months ago #52636 by @quila
Replied by @quila on topic Re: Kunena forum look help
Hi danmc,
check the option "Use Joomla Style" in Kunena Configuration, should be set to "No".
Also try to disable any SEF/SEO component you are using.
Regards
