Question default_gray wrong post order
16 years 4 months ago #51431 by zaitx
I have problem with random wrong post order.
im using default_gray style.
Posts are shows before author post any solution?
16 years 4 months ago - 16 years 4 months ago #51463 by sozzled
G'day, zaitx, and welcome to Kunena. Well, perhaps I should say welcome to our discussion forum because if you are using the default_gray template then you must have been using Kunena for a very long time because that template has not been available for many months.
The display order of messages (last-post-first vs. first-post-first) is a known issue with the default_gray template ... and it's not the only issue with it either as any search of this forum will show you).
For your benefit and the benefit of others who are in your situation I will answer your question by referring you to what we have written before: I'm sorry but, although your question is a commonly-asked one, it is not really a matter of support or finding a solution (other than to use the default_ex template) because the default_gray template is not supported and has not been supported for a very long time.
Last edit: 16 years 4 months ago by sozzled.
