Question Hide BBCode [URL] for non registered users
  • C0n
  • C0n's Avatar
  • Offline
  • Premium Member
  • Premium Member
  • Only the strongest will survive
16 years 1 month ago - 16 years 1 month ago #62585 by C0n
@quila wrote: Hi Milutin,
replace the file kunena.parser.php
components / com_kunena / lib /
with this one attached. This hack hide all link in the post from unregistered user.
File Attachment:
File Name: kunena-20091006.zip
File Size:10.55 KB
Kunena 1.5.6
etusha wrote
will be good if u add this hack at KUNENA 1.5.7 ( by default )
yes will be good but there is a problem if someone want to show link.
In that case we need to have possibility to choose in the configuration, but this is for K1.6 ;)
Thanks quila for this example code i took a look and studdied it for a bit and then compared it to the current kunena 1.5.12 code and relised how you were making it invisible to unregistered users.
$kunena_my = &JFactory::getUser(); if ($kunena_my->id==0) { // Hide between content from non registered users } else { // The code for the url tags to be displayed }
Last edit: 16 years 1 month ago by C0n.
  • C0n
  • C0n's Avatar
  • Offline
  • Premium Member
  • Premium Member
16 years 1 month ago - 16 years 1 month ago #62587 by C0n
Although i already found a bug with both sources :p that this will only work on url links that have been wrapped in url tags
[url][/url]
if its not been wrapped in url tags and it just uses www.domain.com then it is still visible to guest users :O ^_^ :silly:
15 years 8 months ago #87575 by Newkun
Hi, isn't there any solution for hiding all of links other than hack files? Can't you put a setting about this in backend in new releases or do you plan this?
If there is no solution still,Can i learn whether does the solution work for Kunena 1.6.3 which was suggested by @quila?
thanks in advance
15 years 7 months ago - 15 years 7 months ago #91141 by Alexey
C0n wrote: Although i already found a bug with both sources :p that this will only work on url links that have been wrapped in url tags
[url][/url]
to hide this one see kunena.parser.php near 320 line and
$tns = '<a href="' . kunena_htmlspecialchars ( $tempstr, ENT_QUOTES ) . '" rel="nofollow" target="_blank">'; $tne = '</a>';
change to
$kunena_my = &JFactory::getUser(); if ($kunena_my->id==0) { // Hide between content from non registered users $tns = ''; $tne = ''; } else { $tns = '<a href="' . kunena_htmlspecialchars ( $tempstr, ENT_QUOTES ) . '" rel="nofollow" target="_blank">'; $tne = '</a>'; }
also
see near 68 line:
$text = preg_replace ( '/(?<!S)((http(s?):\/\/)|(www\.[a-zA-Z0-9-_]+\.))+([a-zA-Z0-9\/*+-_?&;:%=.,#]+)/u', '<a h ref="http$3://$4$5" target="_blank" rel="nofollow">$4$5</a>', $text );
change to
$kunena_my = &JFactory::getUser(); if ($kunena_my->id==0) { // Hide between content from non registered users $text = preg_replace ( '/(?<!S)((http(s?):\/\/)|(www\.[a-zA-Z0-9-_]+\.))+([a-zA-Z0-9\/*+-_?&;:%=.,#]+)/u', '['.JText::_('COM_KUNENA_A_REGISTERED_ONLY') .']', $text ); } else { // The code for the url tags to be displayed $text = preg_replace ( '/(?<!S)((http(s?):\/\/)|(www\.[a-zA-Z0-9-_]+\.))+([a-zA-Z0-9\/*+-_?&;:%=.,#]+)/u', '<a href="http$3://$4$5" target="_blank" rel="nofollow">$4$5</a>', $text ); }
Last edit: 15 years 7 months ago by Alexey.
The following user(s) said Thank You: supersasho
15 years 7 months ago - 15 years 7 months ago #91150 by supersasho
I edited the previous post i wrote here. I left a line "return TAGPARSER_RET_REPLACED;" so it didn't work for me. Right now it works and i can only say THANK YOU!!
Last edit: 15 years 7 months ago by supersasho. Reason: a made a mistake
