This is not a support forum for sh404SEF or its related products. For sh404SEF support you should visit sh404SEF .
The information given in this category is intended to guide users who want to use sh404SEF with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of sh404SEF.
Solved Problem with category access - access denied
12 years 8 months ago #154241 by allenjj
htaccess: Exists | PHP environment: Max execution time: 660 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : ja_social | author: JoomlArt.com | version: 1.0.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Third-party components: AlphaUserPoints 1.9.3 | CommunityBuilder 1.9.1 | UddeIM 3.2
Third-party SEF components: sh404sef 4.3.0.1671
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
12 years 8 months ago - 12 years 8 months ago #154242 by sozzled
Thank you for providing us with your configuration report. I can see two things that will affect how people are able to access the forum on your site:
(1) sh404sef: please read To what extent does sh404SEF support Kunena? . You should contact the developers of sh404sef if you encounter any problems using K 3.0.4 with their product(s).
(2) You should change the forum integration plugin settings as shown in red below:
Kunena - AlphaUserPoints Enabled: activity=1 avatar=0 profile=0 activity_points_limit=0
Kunena - Community Builder Enabled: access=0 login=1 activity=0 avatar=1 profile=1 private=0
I hope this helps.
Last edit: 12 years 8 months ago by sozzled.
12 years 8 months ago - 12 years 8 months ago #154244 by allenjj
Uninstalling SH404 resolved the primary issue. In your post you suggest correcting the red items. Actually dont know how I missed that, but usually Im careful to read about compatibility problems and for whatever reason we didnt have an issues during testing. Glad its gone as a mis-behaved piece of software is never a nice thing so thank you for the guidance.
Am I to assume that these are settings you suggest addressing in the second part of your post are in the plugins? I would assume a 1 is enable and 0 is not, but can you please confirm?
Last edit: 12 years 8 months ago by allenjj.
12 years 8 months ago #154245 by rich
Confirmed, you're right.
