Important Catchable fatal error: Object of class stdClass could not be converted to string
I use latest Joomla 1.5.11 with Community Builder 1.2.1 and Kunena 1.5.3
I found ability integration of Kunena forum with Coummunity Builder and used it for Avatar Integration, Profile Settings and as Private messaging component instead forum functions.
The problem is that:
All topics, where user writes some posts, becomes subscribed. If you try to unsubscribe using Community Builder profile editor (forum tab), you'll get such error
Catchable fatal error: Object of class stdClass could not be converted to string in /public_html/components/com_comprofiler/plugin/user/plug_cbsimpleboardtab/cb.simpleboardtab.model.php on line 189
Is there a problem with CB 1.2.1 and it's forum tab/pluhin or with incorrect Kunena integration?
BTW, where should I find some user's forum setting using such integration? If it is not reachable throug CB, how can users configure forum functions?
Would you be so kind, if your Kunena forum and Community Builder are not compatible, please do not make vague allusions to the possibility of integration.
Guys, it's a good try, but still you have a lot of work for integration before make such buttons in configuration pannel of your forum at backend.
Yes, I've encountered this problem in the past. It was one of the reasons that I changed the way I configured Kunena to this preference:All topics, where user writes some posts, becomes subscribed. If you try to unsubscribe using Community Builder profile editor (forum tab), you'll get [an] error ...
Integration » Avatar Integration » Use avatar picture from = Community Builder
Integration » Profile Settings » Profile = Kunena
I realise, however, this doesn't answer your questions.
In the first place the behaviour of "all topics where [a] user writes some posts, [the user] becomes subscribed" is the "default" for a Kunena installation. I would recommend you disable that feature. What happens is that when you post a message, the subscribe checkbox is automatically checked by default (you can uncheck it and you won't be subcribed). This behvaiour cane be changed with the following setting:
Frontend » User related » Post-subscription checked by default? = No
The second issue, how to unsubscribe using the Community Builder forum tab, is more complicated. As I mentioned before, I had this problem with previous version of CB. I haven't tested it with CB 1.2.1. From what you write, the defect is still there. This is a matter for the folks at Joomlapolis to advise. In the meantime, you can unsubscribe your favourites using the standard Kunena functions.
- woonydanny
- Elite Member
- Thank you received: 22
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
Where is the fix?
- lex thoonen
www.joomlapolis.com/component/option,com...id,100561/catid,100/
good luck!
