This is not a support forum for Community Builder or its related products. For Community Builder support you should visit Joomlapolis .
The information given in this category is intended to guide users who want to use Community Builder with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of Community Builder.
Question URL Too long for kunena db (max 50 char)
3 years 6 months ago - 3 years 6 months ago #228112 by tlweb
i've got kunena and community builder running. And i have a customer url that is too long to go into kunena user profile info. it is past the 50 char limit. Is it possible to increase this limit?
Kind regards,
Tom
Last edit: 3 years 6 months ago by tlweb.
3 years 6 months ago #228113 by rich
Yes, it's possible. You can increase the value in the table #__kunena_users -> Structure -> websiteurl -> varchar(50).
3 years 6 months ago #228114 by tlweb
Yeah i did already but that feels like a "hack". Would be nice if this could be increased in future versions of kunena.
3 years 6 months ago #228116 by rich
In principle, it makes no difference whether Kunena increases it or you do it yourself.
You are the first user for whom the value varchar 50 is too small, so I think your increase can be classified as a user-defined change.
The following user(s) said Thank You: Joe_Knows
Time to create page: 0.158 seconds
